Red Wine and Cotton
3% peroxide 10% volume, 12 percent =40 volume,
Cobbs is 15 % and is 50 volume.
Cti usr is 12% or 40
Volume.
I think Bristor sells a 20% white knight but you really want to be carful going to strong.
I cut Cobbs in half on pet stains
Reactions: Larry Cobb
Do you know when to use a reducer instead of an oxidizing product? How each works?
I haven't taken a class in ten years, I've forgot a lot. Because I've done so many rentals I got in the habit of just using stain magic on everything first, I know that's wrong but I usually don't know what I'm dealing with neither.
So to answer your question, no. But I usually get lucky.
Reactions: Mike Pailliotet
The white spots are my last attempt to remove a different stain. It was a red40 stain. How should I approach this new dilemma without weakening the color any more?
Since the 40 vol. turned the red stains white, I would definitely try a reducing agent.
We would use DC FiberBrite powder first on uphol, since it is milder.
If that doesn't work, then a stronger reducing agent like ReduceAll is required.
http://www.cobbcarpet.com/zen/index...search_in_description=1&keyword=DCFBR+or+DCRA
icleancarpetz
Rafael Samson
Got that right!
Reactions: Mark Saiger
You got it right.
Always use stain magic or stain 1 first
If ypu need to choose between oxidizer or reducer. After several complete flush rinses-- then go to reducer - Red 1 or red relief if needed.-- we rearly have to use these two.
Using reducer 1st will reduce the results of oxidizer.
Reactions: Jimmy L
I've got some chemspec coffee stain remover that I'll start off with. What do you guys recommend on the dilution of it?
Label directions as a starting point.
Inconspicuous place (if there still is one) as a matter of best practice. Start little to determine MO.
icleancarpetz
Rafael Samson
Yeah used it the other week. Had an unopened container bought years ago. Decided to use it. Works well but will offend the homeowner. Used a little in spray bottle.
Not again.
J. Brightwell
I've always had good luck with Stain Magic for Wool and normally will cover with plastic. Also a clothes steamer for particularly stubborn stains.
Stain magic for wool is just the normal stain magic diluted down 50%...??? Am I correct on that?
J. Brightwell
It's a two part system. Part A is an oxidizer and Part B is a reducer. (I believe. CTI chick?) It also comes with a neutralizer which I never use and which I would rather not be included. If you go with this, try not to mix more than you will need. Once mixed, anything not used is waste.
The "... for Wool" products include a neutralizer that can be used to either stop the action or can be applied to areas that you don't intend to treat as a protection.
I tried all I had on it.
1. Treated it with acid based
rinsed
2. Treated it with fine fabric respray
rinsed
3. Treated it with browning treatment
rinsed, and treated it again
4. Put it outside in the sun with 3% peroxide
Instructed the customer to apply it again after it dried
Yes, I let all my chemicals dwell, and I got it to lighten up about 50% lighter. The browning treatment showed the most difference.
I'll have some pictures to show after it dries fully
Patience is often a necessary ingredient to stain removal. Maybe try the 3% peroxide again. Might also try the browning treatment again, although you did not specify what type of browning treatment it was (some are oxidizers, some are reducers, some are acids). Small steps with products that are not too aggressive but repeat as long as you are making progress.
Reactions: Jim Pemberton
It was Chemspec's liquid browning treatment. It's all I had with me. I told the customer to re-apply the 3% after it dries and if it keep getting lighter to spray again as needed.
J. Brightwell
Correction to my description of Stain Magic for Wool. Part B is a catalyst, not a reducer, that makes the two components work together more effectively.
From CTI: Part A is an oxidizer and Part B is the catalyst. When you mix them together it creates a reaction that is stronger than either of them separately. But this comes at a cost. Once mixed the combined solution will retain full strength for only a short time (30 minutes or so) after that it starts to decline. Which is why Stain Magic for Wool directs you to use shorter dwell times with repeated applications if necessary.
Thanks
Looks much better Matt. You are at the point where as long as the reducer is rinsed out, you can apply a product like Stain Magic or Eliminate. The 2 parts are peroxide and ammonia. The ammonia boosts the action of the peroxide and it self neutralizes. Light spray over the affected area and it should lighten up.
Usually Amonia is the catalyst for peroxide.
And an acid is the catalyst for reducers.
