renegade_cowboy
- Joined
- May 7, 2008
- Messages
- 8,180
- Name
- I'm Rick James
Mytee sells the fresh tanks that can go over wheel frame..
Doc Holliday said:That barrel does look much better, it's clean and has an attempt at safety. Doubt it would hold up in an accident but then I don't know many water tanks that would unless bolted through the floor.
However it's still a barrel with a hole in it, 50 gallons is really too small for most cleaners needs and is going to require frequent refills.
If it works for you fine but I'd want at least two of those barrels but then at that point I'd go to a true "water tank" and save space.
Marty said:No, that is not a TCS install. It makes me sad to think that Les has been hanging out with Satan long enough to have been influenced by him to that degree.
Come on Les, you are personally better than this and your machines should be respected enough not to make it necessary to stoop to that level.
joeynbgky said:Les us right. I would rather have stainless. But, I feel aluminum is good enough and cheaper. Im not knocking anyone. Both machines are good...
But tcs has a silencer on them for the blower and engine. Which makes them much quiter when running
Sent from my T-Mobile G2 using Tapatalk
Marty said:All I'm saying is you should be successful enough by now to not have a need to bash your competition. Let your thousands of happy owners do it for you, if necessary.
And, I really doubt you are interested in seeing a picture of my install, but if you are, all you have to do is look at Joey's. That's another thing I like about TCS. They have everything standardized and down to a system.
their is no proper way to install a 55 gallon drum in a van,due to it weighing over 400 lbs.
joeynbgky said:It has support brackets all around it and its bolted to the waste tank. My 55 gallon holds 55 I can do 2 or 3 apartments with it
joeynbgky said:Wow.......... this thread is not suppose to bash companies... both judson and tcs are similar, but there are differences. Yes its a 55 gallon drum. The pic les posted of the tank was not a tcs install. Some ediot installed that themselves. Both are good companies are both produce top notch machines.
Can we see a pic of a judson waste tank? And a freshwater tank?
joeynbgky said:With all due respect les..... your making fun of my 55 gallon drum? That fresh tank is held down with cloth strapes. Do u have a metal one? Or just made to order. Cause from what I'm seeing the tanks are made out of same material..... just a different shape. Love the pics though. I would take ur machine in my. Van with a 55 gallon drum over that
