The birth of an Aero Tech XT
Lint Basket
Scott Mckay
Draper my fuel costs per year are around $9000. Doc is correct, I'll spend $9000 a year dual wanding or single wanding jobs. Three jobs a day or five jobs a day same fuel used but it still is not through the roof I don't think.
At least when we are going to connect the vac hose to the wand we can tell our trucks are running?
I couldn't tell if those butlers of yours were even on except for all of the noise!
Boom! 2 for 2! Keep um comin!
tmdry
Bill Martins
What are the differences between all the Aerotechs from old to new?
rwcarpet
Robert Hodge
Silencer has been mounted. Also notice how the box frame is bolted to the chassis frame.
Inlet tubing from blower to recovery tank has been installed. Kinetico water softener has been installed.
Kinetico water softener fully plumbed.
control panel being assembled and wires labeled with #'s
Control panel installed inside box.
Where does the Kinetico dump the brine rinse during recharge? Mine is plumbed directly into the waste tank.
Dave Rampage
My 2005 is almost identical to the new one. There are a few minor differences. I don't have a duel pressure regulator. I have the new silencer since my crash.
Dave Rampage
My blower looks and sits just like the one in the picture. My truck is about 90 decibels, 10 feet from the truck
rwcarpet
Robert Hodge
Can the Aero Teck vehicle be serviced by the owner, or does it have to go to a dealer for oil changes and stuff?
This has been the best advertisement thread ever and in a positive way.
They just show their machine, how it is built and answer questions.
Outstanding.
Me too
I hope other manufactures want to follow what AT has done here.
All those units Marty listed have a 20 horse power imitation so true dual wanding is out of the question...fyi...
Reactions: Art Kelley
Cleantechsk
Dustin
Engine oil - extremely easy, one large filter on mine that goes straight up. Nearly filled it with 2 liters of oil to give you an idea of the size
blower oil - easy, especially if you put their new drain valves that are pictured here a few posts ago!
pump oil - drains out super easy.
pto - grease gun + and a piece of cardboard - easy
more room and easier on this thing then my previous cleanco/butler hybrid lol
just one oil filer now?
My UD has two..
How about fuel and water separator filters?
If you have an older ud, you should have 2 filters. The main large one you have mentioned and an oil bypass filter. I believe 2005 and newer have a different motor altogether.
My UD has two..
Thats because those old log wagon UD's have to work so damn hard just to get out of your drive way..they need all the filtering and help they can get.......
when the day ever comes and you feel the power of a real truck under you....you won't know what to do with yourself.......
Cleantechsk
Dustin
you guys must have a completely different engine then
mine is fairly peppy all considering ( even fully loaded)
drove my buddy's 6 liter cube van with empty water tanks and mine blows that out of the water....
captaincarpet
Thomas Cermak
My AT is just over 7 years old, and the machine is still a monster! Other than regular truck repairs/maintenance & belts for the machine I have only had 2 parts fail, the 7 gallon solution tank leaked and needed replaced, and 1 digital readout for water temperature... Much better than ANY machine I've run in the previous 29 years before this one!
Reactions: Lee Stockwell
cu
Without question fantastic truck and engineering . Almost a work of truckmount art. ( just to big to hang on the wall)
and I'm sure a world away form what the old v/at s where.
Its not for me or my business model as it is . But I can see the beauty in that beast.
Aero Tech XT
we have loaded some equipment on the driver side racking system. Here are some new wand holder we came up with.
We will have a few more items like upholstry tools and stair tools hanging at the show. As you can see, there is a lot more room for equipment on the wall.
A few gallons of chemical and some air movers loaded up.
Ceiling hooks for carpet rakes, grout brushes, etc.
Vacuum hose and 3000 psi, 310°F rated solution hose has been loaded up. The red sleeves on the solution lines are our safety sleeves. If a crimp were to fail, this helps get water away from the operator.
Aero Tech XT
The grey hose is being used to fill up the fresh water tank so we are prepared to give demo's at the show. The blue hose is there to be used to fill chemical jugs (pump sprayers, hydro force injection sprayers, etc). This will give the operator high flow since it is a 5/8" hose, up to 170°F water, and wont have the spray back from using a pressure line to fill jugs. Its plumbed with a quick connect so it can easily be removed.
storage space behind the seats.
Storage space above the visors. Those black knobs are to control the power adjustable mirrors (new feature for 2014 chassis).
Aero Tech XT
Did anyone notice the choice of carpet wands and how they were organized?
Ha Ha Ha This is a good example of evolution is the industry!
to remove a wand from its bracket, you just straighten the wand into a more vertical position and it comes right out.
what do you think of the carpet wand brackets?
Aero Tech XT
Here is a better look inside the recovery tank.
Stainless steel Internal recovery tank filters.
Fresh water automatic shutoff float valve
a look inside the float valve
a look inside the fresh water tank. This is one of the baffles.
