- Joined
- Oct 9, 2006
- Messages
- 64,833
- Name
- Rico Suave
Drinking!
Drinking!![]()
Want accountability / Here it is...
The EPA has a program called DFE - Designed For the Environment. What does the EPA look for in their certification? Three things:
1. They look at each raw ingredient to make sure it's safe for the environment.
2. They look at how the raw ingredients interact with each other, to make sure it's safe for the environment.
3. They look at how the product is intended to be used to ascertain that it's safe for all concerned (environment, occupants, technicians).
Releasit Bio-Encap is DFE certified. It is SAFE for the environment.
http://releasit.com/green-encap-cleaning/green-encap-cleaning.html
All hypothetical, admit it how much experience do you have using a Cimex and Encap cleaning. Nuff said!!!Do the same while vacuuming and it will appear to be a dust storm all the while breathing in the "pixie" dust.
All I want is to be able to use the product in good conscience know the product has been tested and found not to be harmful or toxic, especially in the future.
Again asbestos was the economical solution that provided good results, and as for me this is a concern.
my guess is, many thousands of $$$What makes bio encap safe and your other juices unsafe or without certification?
Next time I am up there we will do some testing of our own to determine if this encap is what is causing all of delusional and frankly quite scary behavior.All hypothetical, admit it how much experience do you have using a Cimex and Encap cleaning. Nuff said!!!
I own your Cimex and it is VERY glad to be away from you and put to work...finally.
Open the window or just watch in a commercial building as Sun Rays come through the window and try to tell me it just stays Down in the carpet.
Really, you are worried about pixie dust?
Take a good look at what you're eating everyday.
Yes and that good but that is not the chem that most guys use, they use all of the other unsafe or not certified chems.
Do yall use this bio version as I have not seen it mentioned much?
I hope your not high speed buffing those hard floors. Creates a lot of bad stuff floating in the air, think about the liability.And yes all of our facilities with the exception of one has gone to hard surface with area rugs
Michaels concerns were not actually addressed. I lost both my father and my brother to cancer from workplace chemical toxins. They are a very real concern in our industry. How does this pixie dust effect our lungs, our bloodstream, our organs. Does it remain in our bodies for extended periods of time? Because as sure as the sun, we are breathing this in, in effect ingesting it, especially if it is broadly presprayed prior to the mechanical agitation.
That would control settled dust but if you are working in that environment you become the HEPA filter. To be safe you should wear at least an N-95.We use hepa air scrubbers when we buff the floors thank you for your concern.
Art for the applicator its usually shower fed through a Cimex so not much change of anyone inhaling particulate.
After its dried, the cleaner generally isn't there, however if it were to become airborne it would happen while vacuuming. If the janitors are using a HEPA vacuums that possibility is diminished even further.
I don't think Michael has an idea how it would become a problem, he is just throwing out there that he is concerned "what if" it happened.
Do they sell them in Texas or do you want me to send you some?![]()
Keep the spray down low and make sure the droplet size is large enough so you're not breathing in a lot of vapor. Not just for Encap products but for all chems you spray.Richard, when I use encap I spray it down and red pad it with my 360i bonnet head. Works great. I've been using this stuff more and more on commercial carpets, then I rinse most of it out where the appearance will be improved by the removal of this slurry. The only chemical I normally use with this much chemical exposure is Grease Eraser, which uses a food grade phosphate as it's active cleaning ingredient and I have great confidence in it's safety.
Send me the address to send them & the BILL.No they don't please send me 4 sets please!
