Derek
- Joined
- Oct 7, 2006
- Messages
- 2,166
- Name
- Derek
it's BIG! i got the 20" model.
apparently, this is a company that, unlike others, doesn't over-exaggerate their dimensions. the brush roll is actually 20 and one quarter inches. this model is 25" wide overall.
i will run it tomorrow for a CGD client's quarterly hall cleaning.
i ran it dry on my bedroom plush just to make sure it powered up. it doesn't have an on/off switch, you just lower the handle by pushing down the "toe" lever and it turns on. i think they should have a safety switch for that maybe on the handle.
so i lowered the handle and it threw me backwards into the wall lol. because the new brushes are so stiff and there was no lubrication (i ran it dry) i guess that is what i get. the bristles are polypropylene, so it isn't recommended that you run them on concrete to soften them. with a demo model i won't do that anyways in case i ship it back. i couldn't raise the handle to turn it off (or it would drive me backwards) so i had to unplug it. definitely a learning curve, hopefully it is a small one but i'll find out tomorrow.
so far the only bad thing i can see, and it could be a big one, is that about 2.25" on both ends of the machine are not cleanable. so along a wall you can't get to that area to clean unless you turn the machine 90 degrees because on the front of the machine, the brush roll is there and cleans up to that edge. but in a hallway?? turning the machine 90 degrees in both directions for hundreds of feet?? idk about that...
the youtube video of it is obviously the 15" model. this 20" model is a beast and is more solid than it appeared on Youtube. it has some stainless on it which adds to the weight. the box had some gouges on the corners after UPS delivered it. i video taped the unveiling but Whittaker had some super high impact Styrofoam on all corners of the box, so it was well protected.
it will be taking up a bigger footprint in the rear of my van than i had anticipated
I just soak my towel in the solution tank and give it a good wipe.
