- Oct 7, 2006
- 50,026
I miss Taco
You might as well change the thing a ma jig and replace the dubity bop while you're at it.
Perfect. Let me know if there's anything I can assist with.Thank you so much, I ordered the parts from amazon $18, and I’m gonna have my guy replace the rest of
The spark plug wires and put those on and flush my radiator too.
I know I should do it!
It’s was fuel hose from tank to fuel pump draw side.Was it FUEL hose or just "hose"?
in that case could be poor connection or damaged wire(s). I had to replace mine on gti . Best check ground wiring first
My guy maybe in over his head.in that case could be poor connection or damaged wire(s). I had to replace mine on gti . Best check ground wiring first
Replace enough parts and you'll eventually fix it.My guy maybe in over his head.
But I talked to another guy whose a customer. And a mechanic for the city of LA fleet of fords and chevys.
He said it could be a misfire and since we already replaced the spark plugs and wires it could be a bad coil.
That a compression test would find the bad cylinder, but probably replacing all the coils wouldn't be a bad idea.
The check engine light goes off. When I reset the computer by taking the battery cable off. It runs better and the traction control light goes off. It takes time for the light to go back on and the car to run rough.
Turns out it's kinda running on what's called safe mode to protect the catylic converter.
So I'll probably replace all the coils and hope I'm done for a minute.
It was running great. Could still be a ground wire but where I bought it has no solution eitherReplace enough parts and you'll eventually fix it.
I believe they are the only manufacturer who is accepted by GM. Long official relationship there is my understanding. I have no problems even when running the Butler all day in Summer. Butler!They seem to mostly resolve these issues without explicitly describing the issues to either their potential customers or competitors.
I think it was a Salesman that told me that... so sure you are right.No, several others including Legends, HM, Cleanco have longtime working relationship with GM.
Under my hood lit up like Christmas in the dark when my wires were bad. It was still running good I thought.It was running great. Could still be a ground wire but where I bought it has no solution either
Ok update, dealership says it’s two injectors and the engine needs to be torn down to fix.
No evap code. Like Empire came up with.
No problem with the catalytic converter.
But Chevy won’t touch it with after market parts, so no it’s a rough run Wednesday to Empire at 8 am for a quick pull of clutch and other parts, they’re gonna put a stock belt so I can drive it back and hopefully get it worked on.
Then once it's all fixed back to empire to reinstall parts.
2.5 hours times two! Probably $300-$500 for the Empire I would guess.
But the engine problems are under drivetrain warranty!
That's just saying your in limp mode really.The effin "traction control light" was the beginning of my problems.
Drive to the ocean, push off a cliff, collect the insuranceT & H COMPLETE AUTO SERVICE
212 E Ave K 6 #350, Lancaster, CA 93535
(661) 945-8770
https://g.co/kgs/1mY4wq
Dropped it off here 12/30
Hes had it three weeks without even quoting me a price on anything.
And he tore the engine up and it's fine.
The number one injector was getting 12 volts way to hot.
Over a week ago. Was supposed to get a harness in Thursday and let me know if it was fixed.
My 570 has been a work horse but with 14 inch of lift under load the engine is starting to bog a little.
I'm going in tomorrow and seeing financially were I stand and if I'm towing it to empire and leaving it to be repoed I'm done with this shit.
I owe 2 more.years to the bank.
And its.cost $750 to have it sit at the place getting fixed.
I can provably make one van work for awhile if my 570 doesn't take a shit too.
I'm just super pissed and dont see a happy ending with this shit.
Shhhhh.Drive to the ocean, push off a cliff, collect the insurance
