BlueLine Thermalwave2 summer/fall project
I’m taking it to the forklift later this week to move it. Rubber mats underneath are getting pulled up.
The waste tank was behind it but I think I’m gonna move it to the left side of the machine for better mounting space and ease of access to the rear and right side of the machine.
The van needs a power steering fluid reservoir, a tuneup, and a new rear door
As for the tm, the water pump needs tlc, and the 185f thermal relief valve needs replaced. 🤞. Once I get it completed, we’ll see what other issues it might have
17CE22B9-854E-4ABB-9ECE-28040E23E8EC.jpeg 2EFED58C-14C5-482E-A811-4DAA6ACBD6C8.jpeg 24D2C782-DA0F-424D-8B84-DA5A76476091.jpeg 7A5382E7-9E74-4E44-BEBC-232DC07DCCCC.jpeg 0B2116DF-0BE8-49D1-9293-D416B87B3896.jpeg
Looks like a lot of unnecessary work
You should be cleaning carpet
I still think you're a prick
All of this "unnecessary" work has saved my ass this week and last week and I AM CLEANING CARPET, due to a shitty supply company we call Jondon not being able to do a simple thing as ship a little oil seal to me for my everest. It's almost 2 weeks and I'm finally getting the parts from another company today that I ordered 3 days ago
I don't regret restoring this van/tm the past year and half I've owned it
Here’s a better video of what it’s doing. My mechanic couldn’t tell if it was the engine or the blower
  • IMG_4597.MOV
    42.1 MB
Matt, sometimes I think you should lock yourself in a room with Joseph Rogers.....
That is your vac relief valve. Adjust it. Or don't adjust it. It's supposed to open when you lock the hose down. If you think it's opening too soon, then adjust it. It's very easy. Just turn the nut on the end.
You mean he should spin around?
That noise goes away when I manually open the vac relief valve. Don’t insult me, I’m not a true dumbass
After all this time working on this headache. you think I don’t know how to work a vac relief valve ???!!!
It shouldn’t be making that sound at 13-14hg
🖕🏻U
Ok, I’ll adjust it
And when you see it making that grinding noise at 13hg
KevinD
Kevin Dumas
As I said the other day, sounds like a air leak.
Today's video, clearly a air leak but it sounds like it is leaking through your relief valve which is normal.
I know you say when you open the valve manually you do not get the noise but you are probably opening the valve further than it does during normal operation causing less restriction and less noise.
listening on my ph all I can hear is vac relief, listening on slightly better wireless speaker I still hear vac relief.. 🙉
welp, do this
crank relief valve tight so it won't open.
cover the hose end half to 3/4 or whatever is needed to load the blower to 14hg.
(make sure vac relief doesn't open at all)
you'll know then if hearing a bearing, belt squealing or air whistling thru the relief valve
so easy, even a Matt can doit
Reactions: Nate The Great
I worked on it this evening and found the problem. That sound is coming from an unevenly adjusted belt tensioner. I went to retighten the belt a couple weeks after the new one was put on and I forgot to loosen the pulley on the back end so it would move. It sounds like a new machine now
An uneven belt tensioner makes the engine sound like it's grinding.
Marty is still a prick
Damon is still a smartass
AJR
Whatshisbutt
i have the same machine been using for years . i have not been over all your posts but here are the part numbers for some stuff you will most likely need for the GM vortec 1.6L
1. timing belt, water pump and tensioner gates KP15310XS (if you go to PSI or other routes these will cost a fortune.
https://www.gatesautocat.com/article/KP15310XS
bought mine at with 3 days shipping $92 https://spareto.com/products/dayco-water-pump-and-timing-belt-set/ktbwp2210
if you need belt asap oreillys Gates T203 111 tooth
2. coil oreillys 23-0228 $81 https://www.oreillyauto.com/detail/...2ae86/import-direct-ignition-coil/odi1/230228
3. wire set oreillys 9666 $34.99 https://www.oreillyauto.com/detail/c/omnispark/omnispark-spark-plug-wire-set/oms0/9666?q=9666&pos=0
most of the other parts you can use the part numbers on the stuff and find it.
i also moved my chem pump to the front of the machine to better access the diaphragm.
AJR
Whatshisbutt
Pulling the water pump out is twice as easy as putting it in 😒
As for the new accumulator...I had to cut the threads in half to make it fit because it’s taller than the original one.
View attachment 108425 View attachment 108426
do yourself a favor and run a high 1/4 pressure hose to the front and mount your chem pump there with a shut off so you can turn it off for tile cleaning . its a bitch to swap the diaphragm in that position.
srd
I refubished one of these about 2 years ago, re powdercoated frame panels and waste tank, stripped the heat exchange off went with a eurotec diesel burner, relocated the computer it was mounted in a bad place originally machine still runs perfectly
View attachment 118235 View attachment 118236
Why did you switch over to diesel? Did it have trouble overheating the computer with no air flow going through the machine?
srd
I really like the eurotec burners small footprint, burn clean, problem free. Guy i got it from said it did, we relocated the computer it was originally mounted on the upper shroud above the exhaust manifold, not sure what the engineers at blueline were thinking with that one lol
There's several questions I'd like to ask them about these thermalwaves. There was a crappy "heat shield" on top of the engine's catalytic converter that did absolutely nothing. It was just a thin piece of metal that laid on top of it. I had to come from the factory because my spare parts machine had the exact same one laying on top of it.
And the liquid heat exchanger provided plenty of heat, but it suffocated the water pump, not allowing any air to escape. I read other's comments about how the water pump's seals melted out west. I know that because they installed a tiny little fan underneath to help air flow. It wouldn't matter because the open air slots in the side panels were so narrow, hardly any air would pull through it. IT's like they wanted these things to overheat
and on my spare parts machine, I discovered this thing sitting in the silencer when I removed the blower a few weeks ago. There's no way it would've survived in one piece if it was sucked in through the blower. It had to be purposely put in there to do nothing but rattle. If the truck mount won't stop rattling, just go buy another one.
1C710D69-1ADD-4852-B8C0-0DD9E543F7D0.jpeg BA604616-593A-44E3-8936-5C19398294F0.jpeg 5631D1C2-5E85-4580-9881-34C453F6C141.jpeg
Do you have some other pictures of the unit during and after the rebuild? And is there anything else you think I might need to look at with any updates?
