dgardner
I always liked the hammertone look, never saw a TM with that finish until now. Nice!
Thank You it has been a blast, I have put off some work this week to try and get her done. I just got some wands and I can't wait to fire her up and put them to the test.Just read this whole thread. Nice very Nice!
Thank you LarryEngineering a TM is not as easy as some think . . .
Lots of details that can require rework . . .
The finished product looks good . . .
That is really part of the fun of it, and not everyone will agree with what you come up with, or like your design, but it really is a lot of fun, can be a little frustrating at times....and you do answer the question WHO THE HELL DESIGNED THIS IDEA!!! it just happens sometimes and the fix is just too far back to correct... fix cut a wrench in half so you can tighten that nut that you are never going to get to in a million years no matter how hard you tryNice thread thanks for sharing. I have great ideas but my engineering sucks. I can't imagine the problems I would have designing a truckmount. Probably run backwards and blow. Lol
Gene
I would say yes because we can dual wand with it no problem, so in that view yes.So would you say its twice as powerful as your Legend or more than that? Do you plan on running two setups off it or one?
pretty cool. now your set up to do a test I always wondered about. Try hooking the blowers up in series and see how high of vac you can pull. If I am not mistaken you can increase max hg's when you do that. My dream machine would be 400cfm single wand machine that pulls 22 hg's
Yes I sure can do that for you all they were very good taking order and getting it to me in a decent amount of time.Share your secret pulley source?
How long will vw engine last? This is a good question, One of the problems vw motors have that causes them to fail is the clutch pressure plate when they are in a car. The in out movement and force of the clutch puts a ton of stress on the crankshaft, and back bearing, it actually over time pushes the crankshaft back into the block....this is called end play on the crank, as these motor get older the end play can go from say a 1/32" to well over a 1/4".Ow long should that vw engine last approximate and and how much do the engines cost??
Great machine...
I had to because it was a weighted pulley and the added thickness was interfering with my belt clearance, I was just really after the center portion of the pulley so we could mount the drive pulley for the blowersWhy did you mill down the pulley?
