dgardner
You know, Kevin’s post and my response got me to thinking. Even if the system worked as advertised, could it dry the example room in 5 minutes? Probably not, it turns out.
Here are my assumptions:
1 gallon of moisture to remove
250 cfm heated air in
250 cfm 85 degree air, fully saturated out (hypothetical, will probably be less than 100% RH)
Machine runs for 5 minutes
We are removing 250 X 5 = 1250 cu ft – or 1250/14 = 89.28 lbs of air from the room. Fully saturated this means we are removing 89.28 X 185 = 16517 grains or 16517/7000 = 2.36 lbs or 2.36/8.34 = 0.28 gallons of water during the 5 minute period.
This means that it would take about 18 minutes to fully remove the whole gallon of moisture from the room BEST CASE. Ouch.
Edit:
I guess the carpet could be called completely dry if we leave the room at 100% RH, so we don’t have to exhaust the whole gallon, we could leave about a quart in the room air. This means we would need only 13 minutes before we called it dry. Still a bit short of the 5 minute claim…
Edit:
