The birth of an Aero Tech XT
Fort Worth , Texas
At that point I think if you are not running 3 wands, you are just going to be working harder with only slight or marginal improvement.
Aero Tech XT
North Salt Lake, UT
Jeremy Wilson
Technical difficulties.......
here is a try at uploading via Photobucket.
back to production of the show truck.
FIFTH STAGE:
in the fifth stage of production, we load all of the major components and finish the final assembly.
Here we have loaded the fresh water tank, #6 blower, water pump / oil level indicator, and recovery tank.
[/URL][/IMG]
Here we have loaded the recovery tank. We are getting ready to install the 2" drain line. It will be plumbed underneath the floor of the box.
[/URL][/IMG]
[/URL][/IMG]
we have installed the blower & water pump belts and are getting ready to install the 5" suction line from the blower to the recovery tank.
[/URL][/IMG]
lower blower belt pulley
[/URL][/IMG]
mirf
New jersey
David Mirfin
Great thread, looking forward to following it. When are you expecting to complete it?
Does the chemical pump still have a 700 psi limit?
If so how does one go about dual wanding tile (no rinse) and upholstery (acid rinse) at the same time?
boazcan
Tampa Bay/Central Florida
Bryan C
I upgraded mine to either 1500 or 3000, can't remember, from the 600 that came with it. I'm pretty sure they matched the chem pump with pressure pump now. We would leave the valve open when doing tile and blow the diaphragm. Finally upgraded it last year.
Sent from my DROID RAZR HD using Tapatalk 4
Aero Tech XT
North Salt Lake, UT
Jeremy Wilson
The chemical pump diaphragm is rated to 1500 psi. We have installed a ball valve in front of it so it can be turned off when pressure exceeds 1500 or to save wear and tear on the diaphragm when not being used.
Aero Tech XT
North Salt Lake, UT
Jeremy Wilson
We are near completion now. Fully tested, just need to finish the organizational racking system and a few finishing touches.
just a little slow getting pics up.
Chris A
OH
any way to build a lighter duty at based off the ISUZU Ecomax platform? I think the gvw is 12000 on those trucks.
Aero Tech XT
North Salt Lake, UT
Jeremy Wilson
We have looked into it. The biggest problem was the transmission didn't have enough torque to run our blower and water pump. There would need to be a lot of changes to the overall design and layout and we just did feel the LITTLE BIT of cost savings would justify it.
Reactions: Chris A
Aero Tech XT
North Salt Lake, UT
Jeremy Wilson
We screw this attachment into the blower and lift them into the box with a forklift.
Here is the drive shaft connecting to the PTO. Only 3 grease zerk fittings.....Easy to access.
This is the lower sheave shaft bearing or pillow blocks. 2 grease zerks to grease. the cover can be left on to grease.
here we are connecting the 5" piping from the blower exhaust to the silencer.
attaching the silencer to the box frame rails.
Aero Tech XT
North Salt Lake, UT
Jeremy Wilson
Silencer has been mounted. Also notice how the box frame is bolted to the chassis frame.
Inlet tubing from blower to recovery tank has been installed. Kinetico water softener has been installed.
Kinetico water softener fully plumbed.
control panel being assembled and wires labeled with #'s
Control panel installed inside box.
Reactions: Erik and Mikey P
