- Joined
- Sep 20, 2008
- Messages
- 10,878
- Name
- Michael
At that point I think if you are not running 3 wands, you are just going to be working harder with only slight or marginal improvement.
I was told pulsation dampers need to be vertical to work?
What is that inch elbow and brass fitting near the top of the waste tank?
I bet that is an inline rinsing hook up to wash out the tank. Or it should be.....
Sent from my DROID RAZR HD using Tapatalk 4
Does the chemical pump still have a 700 psi limit?
If so how does one go about dual wanding tile (no rinse) and upholstery (acid rinse) at the same time?
Brine spooge from the Kinetico softener it turns out..
Great thread, looking forward to following it. When are you expecting to complete it?
How is this unit different than a CINTAS truck?
any way to build a lighter duty at based off the ISUZU Ecomax platform? I think the gvw is 12000 on those trucks.
