- Apr 17, 2009
- 10,171
- Name
- Kenny Hayes
You know it's dried to a bone and dyed the carpet
You'd have to chop it with an axe just to get it started
If you are a padder I suppose.You know it's dried to a bone and dyed the carpetYou'd have to chop it with an axe just to get it started
Most of the chemical manufacturers claim their product, when used properly, dries to a powder. Maybe not a hard polymer crystal but a powder anyway. I've tested quite a few products and found that many do. Especially products like Procyon or Carpet Details. You see it building up on your hydro-force or on your quick connects. When you brush it, it's just like dust. I have no problem with carpets re-soiling because of sticky residues. Most of my work is repeat customers. One of my friends has gone 100% VLM and he finds it very slow and tedious. He often wishes he had his truck mount back on certain jobs. VLM certainly has its appeal, especially with the low cost of equipment but truck mounts have the ability to perform quickly and efficiently.GROUP THINK Members still ignore '' The QUESTION ''
What happens to all that's left behind using HWE
You have a TM and Van sitting outside, blasting away, burning fuel, loaded with equipment that cost you probably $30,000 - $50,000 dollars
With that kind of money the carpet should be dry the minute you drag a wand across it
But NO it still takes 2-5 hours to dry ( if your lucky )
And leaves behind prespray detergent dirty water and dirt
I tell all my customers HWE is how carpets were cleaned in the 90's
VLM with NO residue and 1-2 Hour Residential Dry times is how carpet is cleaned today
I love VLM !!!
That's what I always thought prespray and detergent dries to a powderMost of the chemical manufacturers claim their product, when used properly, dries to a powder. Maybe not a hard polymer crystal but a powder anyway. I've tested quite a few products and found that many do. Especially products like Procyon or Carpet Details. You see it building up on your hydro-force or on your quick connects. When you brush it, it's just like dust. I have no problem with carpets re-soiling because of sticky residues. Most of my work is repeat customers. One of my friends has gone 100% VLM and he finds it very slow and tedious. He often wishes he had his truck mount back on certain jobs. VLM certainly has its appeal, especially with the low cost of equipment but truck mounts have the ability to perform quickly and efficiently.
The more you try to clean soil filtration, often the worse it gets. There are times when it's best to leave it alone.Well maybe when I'm crawling around on my knees trying to get Soil Filtration lines out I wish I could just put a wand and flush them out but Soil Filtration was a Pain in the Ass with HWE too but not as much as it is with VLM
That's the only time I wish I had a TM and Wand bad soil filtration along baseboards in the crevice
Padding is so 80s.GROUP THINK Members still ignore '' The QUESTION ''
I love VLM !!!
Nah. The alkaline prochem restoration and or Harvard's grime release mixed up strong are the two best to remove itThe more you try to clean soil filtration, often the worse it gets. There are times when it's best to leave it alone.
And this is the probably the most accurate response. Because I know you LMC the high rise buildings very frequently (which you should) and I'm aware how often you use your truckmount as well.Most of the chemical manufacturers claim their product, when used properly, dries to a powder. Maybe not a hard polymer crystal but a powder anyway. I've tested quite a few products and found that many do. Especially products like Procyon or Carpet Details. You see it building up on your hydro-force or on your quick connects. When you brush it, it's just like dust. I have no problem with carpets re-soiling because of sticky residues. Most of my work is repeat customers. One of my friends has gone 100% VLM and he finds it very slow and tedious. He often wishes he had his truck mount back on certain jobs. VLM certainly has its appeal, especially with the low cost of equipment but truck mounts have the ability to perform quickly and efficiently.
We come across filtration lines that won't be touched by anything. 20 year old carpet and you still see the teeth marks of the kicker used to install the carpet. I've used every product and every tool over the last 40 years. Some we can improve and even remove completely but it's going to come back. Unless you can rinse these products out thoroughly, it just adds to the mix. They might not be as bad where you are but here, depending on the location, they are absolutely horrendous.Nah. The alkaline prochem restoration and or Harvard's grime release mixed up strong are the two best to remove it
But for this debate to keep going around in a circle only because the fake steamwaypro keeps rambling about how buffing is the best and only way it should be cleaned is a joke
How does your friend clean Residential carpet using the VLM MethodMost of the chemical manufacturers claim their product, when used properly, dries to a powder. Maybe not a hard polymer crystal but a powder anyway. I've tested quite a few products and found that many do. Especially products like Procyon or Carpet Details. You see it building up on your hydro-force or on your quick connects. When you brush it, it's just like dust. I have no problem with carpets re-soiling because of sticky residues. Most of my work is repeat customers. One of my friends has gone 100% VLM and he finds it very slow and tedious. He often wishes he had his truck mount back on certain jobs. VLM certainly has its appeal, especially with the low cost of equipment but truck mounts have the ability to perform quickly and efficiently.
The marks of the knee kicker isnāt filtration soiling. Thatās why itās not coming out. I think itās oxidation which might need to be treated with rust removerWe come across filtration lines that won't be touched by anything. 20 year old carpet and you still see the teeth marks of the kicker used to install the carpet. I've used every product and every tool over the last 40 years. Some we can improve and even remove completely but it's going to come back. Unless you can rinse these products out thoroughly, it just adds to the mix. They might not be as bad where you are but here, depending on the location, they are absolutely horrendous.
Ive had wood stain transfer off bottom of doors.The marks of the knee kicker isnāt filtration soiling. Thatās why itās not coming out. I think itās oxidation which might need to be treated with rust remover
Buffer works just fine for me. And i can strip vct and put a brush on it to prescribe.Don't use a Buffer
Most of the work is done by a $3000 dollar 14'' CRB and it's worth every penny
Then a OP Machine - TOPS Odyssey or Tankless Vibe
View attachment 133115View attachment 133116
Iām not anti VLM. VLM/encapsulation absolutely has its place. We use it in quarterly rotation with HWE on commercial and we will often use it in conjunction with HWE in residential. Typically post bonnet.GROUP THINK Members still ignore '' The QUESTION ''
I love VLM !!!
It's definitely filtration soiling. The kicker puts holes through the carpet backing and air filters through them.The marks of the knee kicker isnāt filtration soiling. Thatās why itās not coming out. I think itās oxidation which might need to be treated with rust remover
He uses a hawk rotary similar to the Swirly. Lately he has been using products from Bonnet Pro, but some vacaway products as well as Saiger's products. He uses a Phoenix for commercial and an Oreck for stairs.How does your friend clean Residential carpet using the VLM Method
And what encaps does he use
Just Wondering
I see that a lotIt's definitely filtration soiling. The kicker puts holes through the carpet backing and air filters through them.
