100% VLM ???
You know it's dried to a bone and dyed the carpetšŸ˜‚ You'd have to chop it with an axe just to get it startedšŸ˜‚
SteamwayPro
George
I would rather be a Padder than a SOAKER
VLM crystallizes and leaves NO sticky dirt attracting residue
Residential dries in 1-2 Hours Commercial dries in 30 - 60 minutes
And HUGE PROFITS
What happens to all the prespray detergent dirty water and dirt left behind by SOAKERS
CRICKETS !!! CRICKETS !!! CRICKETS !!!
That just tells me (when you had a machine that looked like a good truckmount) that you didn’t HWE carpet properly
I bet you
-did your wet passes in the triangle pattern
-had a 2 jet wand that was 2-3 flow
-rinsed at maybe 350psi
-didn’t do slow dry passes.
-never changed your blower belts because it was ā€œtoo hardā€ to get access
-had your lift set around 11-12
Which made your mind calculate that HWE was terrible method. I understand. That’s why there’s mental facilities for those who were just taught the wrong way. It’s called a class and they teach you the proper way to HWE carpet.
SteamwayPro
George
GROUP THINK Members still ignore '' The QUESTION ''
What happens to all that's left behind using HWE
You have a TM and Van sitting outside, blasting away, burning fuel, loaded with equipment that cost you probably $30,000 - $50,000 dollars
With that kind of money the carpet should be dry the minute you drag a wand across it
But NO it still takes 2-5 hours to dry ( if your lucky )
And leaves behind prespray detergent dirty water and dirt
I tell all my customers HWE is how carpets were cleaned in the 90's
VLM with NO residue and 1-2 Hour Residential Dry times is how carpet is cleaned today
I love VLM !!!
  • Love
Reactions: frank fratto
I love VLM !!!
Most of the chemical manufacturers claim their product, when used properly, dries to a powder. Maybe not a hard polymer crystal but a powder anyway. I've tested quite a few products and found that many do. Especially products like Procyon or Carpet Details. You see it building up on your hydro-force or on your quick connects. When you brush it, it's just like dust. I have no problem with carpets re-soiling because of sticky residues. Most of my work is repeat customers. One of my friends has gone 100% VLM and he finds it very slow and tedious. He often wishes he had his truck mount back on certain jobs. VLM certainly has its appeal, especially with the low cost of equipment but truck mounts have the ability to perform quickly and efficiently.
SteamwayPro
George
That's what I always thought prespray and detergent dries to a powder
What happens to the dirt that's in the dirty water. Water evaporates and dirt settles at the bottom of the carpet with the powder ???
Yes on Residential medium to heavy soil HWE is faster. You can't just blast dirt away with WATER PRESSURE. It can be slow and tedious
I NEVER wished I had my TM back
NEVER NEVER NEVER !!!
SteamwayPro
George
Well maybe when I'm crawling around on my knees trying to get Soil Filtration lines out I wish I could just put a wand and flush them out but Soil Filtration was a Pain in the Ass with HWE too but not as much as it is with VLM
That's the only time I wish I had a TM and Wand bad soil filtration along baseboards in the crevice
The more you try to clean soil filtration, often the worse it gets. There are times when it's best to leave it alone.
Rick J
rick Jones
This discussion gave me an idea for today's video. Thanks ā˜ŗļø
View: https://youtu.be/-F6MiguGzPU
memories, decades ago, just dipping my toe into VLM.
had a very high end apartment community. high rise, elevators etc.
porty all the way. WHITE , sculptured olefin(of course) berber.
The common halls were polished concrete. When you entered the units you would have thought that on the other side of the door there had been a fire.
All the particulate from the halls filtered under the doors onto the entry tile , and all over the carpet, throughout the units.
It was actually difficult to get it off of the entry tile.
My query to the Excellent Supply people (not sure who, or if Rick)
can I use your stuff as a HWE cleaning agent, to try and prevent wicking of this fine ,almost like toner, particulate which is all throughout the units.?
The response, back then, maybe when Punch was just a twinkle in Rick's eye šŸ˜ , was pretty much silence. (wheels turning?)
they live
Steve
I love VLM !!!
Padding is so 80s.
Just google best method for cleaning carpet lol.
I felt guilty charging a lot then telling the customer they had finish the job for me.
When will you stop deceiving your customers and change your name?
SteamwayPro
George
OK so the answer to '' The Question '' is ...
Prespray and detergent dry to a powder
Dirty water evaporates and all that dirt in the dirty water settles at the bottom of the carpet with the powder
Doesn't seem worth it to me
$30,000 $$$ PLUS for equipment to clean carpet, that takes 2-5 hours to dry ( if the customer is lucky ) and leaves behind dirt and powder in the carpet
TRUTH
But GROUP THINK Members HATE the TRUTH
Just seems like there should be a BETTER, FASTER Drying, and MORE Profitable Way to clean carpet today
I love VLM !!!
Nah. The alkaline prochem restoration and or Harvard's grime release mixed up strong are the two best to remove it
And this is the probably the most accurate response. Because I know you LMC the high rise buildings very frequently (which you should) and I'm aware how often you use your truckmount as well.
But for this debate to keep going around in a circle only because the fake steamwaypro keeps rambling about how buffing is the best and only way it should be cleaned is a joke
SteamwayPro
George
Don't use a Buffer
Most of the work is done by a $3000 dollar 14'' CRB and it's worth every penny
Then a OP Machine - TOPS Odyssey or Tankless Vibe
We come across filtration lines that won't be touched by anything. 20 year old carpet and you still see the teeth marks of the kicker used to install the carpet. I've used every product and every tool over the last 40 years. Some we can improve and even remove completely but it's going to come back. Unless you can rinse these products out thoroughly, it just adds to the mix. They might not be as bad where you are but here, depending on the location, they are absolutely horrendous.
  • Dislike
SteamwayPro
George
How does your friend clean Residential carpet using the VLM Method
And what encaps does he use
Just Wondering
The marks of the knee kicker isn’t filtration soiling. That’s why it’s not coming out. I think it’s oxidation which might need to be treated with rust remover
Reactions: jessi
they live
Steve
Ive had wood stain transfer off bottom of doors.
Sally's took care of it.
they live
Steve
Swani
I love VLM !!!
I’m not anti VLM. VLM/encapsulation absolutely has its place. We use it in quarterly rotation with HWE on commercial and we will often use it in conjunction with HWE in residential. Typically post bonnet.
But for residential carpet, hot water extraction should be the primary system. VLM just doesn’t check all the boxes.
I’ve had quite a few homeowners ask me about VLM after someone tried to sell them on it as ā€œthe new, better way.ā€ I always ask them one simple question. How do you think they clean their bonnets?
They’re not spritzing them with a little encap, wiping them with a rag, and giving them a quick vacuum at the end of the week. Those pads have to be properly washed between jobs.
Once I explain that, most people instantly get why I lead with HWE for residential and only use VLM/encap as a tool, not a replacement.
It's definitely filtration soiling. The kicker puts holes through the carpet backing and air filters through them.
Reactions: SteamwayPro
Just Wondering
He uses a hawk rotary similar to the Swirly. Lately he has been using products from Bonnet Pro, but some vacaway products as well as Saiger's products. He uses a Phoenix for commercial and an Oreck for stairs.
SteamwayPro
George
I see that a lot
Knee kicker puts small holes in the carpet. Air flow under the carpet flows up through those holes and leaves filtration soil on light carpet
I use VacAway Spot-N-Boost Green at 50/50 and in some cases VacAway Commercial Magic at 4 oz per gallon. Run CRB straight in up to baseboards and get on my knees and use drill brush and Grout Brush
The soil filtration from knee kickers is a few inches out from the wall and is easier to remove for me but the soil filtration in the crevice all along the walls is very difficult to remove completely. I just try to make it look better
I explain soil filtration to customers how it happens and why it happens before I start working
Most customers understand and don't expect miracles. Customers that want miracles I just turn down job
LESS water MORE agitation !!!
