100% VLM ???
You know it's dried to a bone and dyed the carpet😂 You'd have to chop it with an axe just to get it started😂
SteamwayPro
George
I would rather be a Padder than a SOAKER
VLM crystallizes and leaves NO sticky dirt attracting residue
Residential dries in 1-2 Hours Commercial dries in 30 - 60 minutes
And HUGE PROFITS
What happens to all the prespray detergent dirty water and dirt left behind by SOAKERS
CRICKETS !!! CRICKETS !!! CRICKETS !!!
  • Haha
That just tells me (when you had a machine that looked like a good truckmount) that you didn’t HWE carpet properly
I bet you
-did your wet passes in the triangle pattern
-had a 2 jet wand that was 2-3 flow
-rinsed at maybe 350psi
-didn’t do slow dry passes.
-never changed your blower belts because it was “too hard” to get access
-had your lift set around 11-12
Which made your mind calculate that HWE was terrible method. I understand. That’s why there’s mental facilities for those who were just taught the wrong way. It’s called a class and they teach you the proper way to HWE carpet.
Reactions: royalkid
SteamwayPro
George
GROUP THINK Members still ignore '' The QUESTION ''
What happens to all that's left behind using HWE
You have a TM and Van sitting outside, blasting away, burning fuel, loaded with equipment that cost you probably $30,000 - $50,000 dollars
With that kind of money the carpet should be dry the minute you drag a wand across it
But NO it still takes 2-5 hours to dry ( if your lucky )
And leaves behind prespray detergent dirty water and dirt
I tell all my customers HWE is how carpets were cleaned in the 90's
VLM with NO residue and 1-2 Hour Residential Dry times is how carpet is cleaned today
I love VLM !!!
I love VLM !!!
Most of the chemical manufacturers claim their product, when used properly, dries to a powder. Maybe not a hard polymer crystal but a powder anyway. I've tested quite a few products and found that many do. Especially products like Procyon or Carpet Details. You see it building up on your hydro-force or on your quick connects. When you brush it, it's just like dust. I have no problem with carpets re-soiling because of sticky residues. Most of my work is repeat customers. One of my friends has gone 100% VLM and he finds it very slow and tedious. He often wishes he had his truck mount back on certain jobs. VLM certainly has its appeal, especially with the low cost of equipment but truck mounts have the ability to perform quickly and efficiently.
Reactions: SteamwayPro
SteamwayPro
George
That's what I always thought prespray and detergent dries to a powder
What happens to the dirt that's in the dirty water. Water evaporates and dirt settles at the bottom of the carpet with the powder ???
Yes on Residential medium to heavy soil HWE is faster. You can't just blast dirt away with WATER PRESSURE. It can be slow and tedious
I NEVER wished I had my TM back
NEVER NEVER NEVER !!!
SteamwayPro
George
Well maybe when I'm crawling around on my knees trying to get Soil Filtration lines out I wish I could just put a wand and flush them out but Soil Filtration was a Pain in the Ass with HWE too but not as much as it is with VLM
That's the only time I wish I had a TM and Wand bad soil filtration along baseboards in the crevice
The more you try to clean soil filtration, often the worse it gets. There are times when it's best to leave it alone.
Rick J
rick Jones
This discussion gave me an idea for today's video. Thanks ☺️
View: https://youtu.be/-F6MiguGzPU
memories, decades ago, just dipping my toe into VLM.
had a very high end apartment community. high rise, elevators etc.
porty all the way. WHITE , sculptured olefin(of course) berber.
The common halls were polished concrete. When you entered the units you would have thought that on the other side of the door there had been a fire.
All the particulate from the halls filtered under the doors onto the entry tile , and all over the carpet, throughout the units.
It was actually difficult to get it off of the entry tile.
My query to the Excellent Supply people (not sure who, or if Rick)
can I use your stuff as a HWE cleaning agent, to try and prevent wicking of this fine ,almost like toner, particulate which is all throughout the units.?
The response, back then, maybe when Punch was just a twinkle in Rick's eye 😝 , was pretty much silence. (wheels turning?)
