Village Idiot
- Jul 13, 2011
- 26,391
http://advrider.com/index.php?threads/chain-o-ring-wd-40-exposure-effects-study-and-results.345397/I don't know a lot about motorcycle chains=
That's an interesting question. Looking at Mike's picture of the gear train it looks like the upper bearings (that you can see) are shielded, not sealed. So now I wonder if the lower bearings (the one(s) that failed, that you can't see in the picture) are sealed or not. The parts list simply shows them as 6003 - that implies a completely open bearing. A sealed bearing would have a part number something like 6003-2RS (2 rubber seals), and a shielded bearing would be 6003-ZZ or similar. If the lower bearings are shielded then they are protected from dust and debris, but not liquid entry.Are the bearings not sealed bearings?!
If the lower bearings are shielded then switching to sealed may help. One report of a problem doesn't mean an epidemic though...
holy snikitysnacks!
Did Steve get a contract to clean the Titanic?
Is that for scraping the ash off toasted marshmallows?
That ain't mine.holy snikitysnacks!
Maybe one of you distributors/dealers should make a video about proper cleaning and maintenance procedures.
Show where it can be washed and how it can be cleaned out properly.....
Instead of the clichés "proper maintenance" or "needs to be cleaned after each day of use".
Well, show them how and where and what can be done.
Michigan just sucks in all regards.
Steve should move to the high desert...
What a day..
